What’s the difference between the Signature and SE versions?
1. EI transformers made with vintage materials.
2. New low-pass filter.
3. Hand-crafted copper capacitors, pair.
4. Copper resistors in the digital section, 2 pcs.
5. Rare diodes, transistors, and resistors in important places.
6. Additional choke in the -15V voltage regulator.
7. Option to install a TDA1541A S1 chip .
8. Option to install a marble front panel.
9. WM8804 SPDIF receiver.
10. High-quality connectors — IEC, RCA, XLR
11. High-quality Sound Care feet.
12. More complex multi strand composition for internal wiring.
13. Use of hand made 2% copper solder.
14. More Black Gate capacitors
15. Longer testing time before shipping
16. Careful tube selection.
17. Noctua cooler
18. Instead of silicon diodes, powerful germanium transistors were used as rectifier, 2pc.
  1. i want buy from you your abbas dac psyche signature edition
