CURRENT STOCK. Updated 25.07.2026. Limited offer.
(Click for description) 1 — DAС U1 Abbasaudio , KIT — $1200 — SOLD OUT
The kit is designed for the PCM63 chips.
The PCM1702 adapters are installed, as the PCM63 is hard to find.
Input receiver: CC8414 (24-bit, 96 kHz)
Digital section : EZ80 rectifier
Output stage: 6SN7 pair, 6X5
Output level: 3v RMS
Set included:
  1. Two assembled and tested PCBs + 2 power transformers
  2. Metal housing ( no RCA and IEC plugs)
  3. Rubber feet
  4. Brass posts and set of screws
  5. Wooden face panel
  6. «Abbasaudio» badge
  7. 1 meter of multi strand wire and 1 m of insulation
  8. 4 tubes
If you do not have the experience and necessary skills to work with electronic circuits, please do not purchase this product.
To purchase, visit https://abbasaudio.com/en/contacts
To see other products for sale, visit https://abbasaudio.com/en/store
(Click for description) 2 — DAС 2.41 Abbasaudio , KIT — $1820 — 1 unit left
The kit is designed for the TDA1541 chip.
The TDA1541 is included
Input receiver: WM8804 (24-bit, 96 kHz)
Digital section : 6X5 ( EZ35), EAA91, E180F ( tube Dem clock)
Output stage: 6SN7 pair, 5V4
Output level: 3.5v RMS
Set includes:
  1. Two assembled and tested PCBs + 3 power transformers
  2. New version of the metal housing (RCA and IEC plugs are included)
  3. Rubber feet
  7. Premium multi-strand wire (2m) and 2m of insulation
  8. 6 tubes
(Click for description) 3 — Linear Power supply, Abbasaudio, $280 — 1 unit left
Shipped within 1 week, delivered to you in 1 to 4 weeks. Delivery time vay vary based on your country. Order rules apply.
2комментария
