CURRENT STOCK. Updated 1.03.2026. Limited offer.
1 — DAС U1 abbasaudio , KIT — $1200
The kit is designed for the PCM63 chips.
The PCM1702 adapters are installed, as the PCM63 is hard to find.
Input receiver: CC8414 (24-bit, 96 kHz)
Digital section : EZ80 rectifier
Output stage: 6SN7 pair, 6X5
Output level: 3v RMS
Set included:
- Two assembled and tested PCBs + 2 power transformers
- Metal housing ( no RCA and IEC plugs)
- Rubber feet
- Brass posts and set of screws
- Wooden face panel
- «Abbasaudio» badge
- 1 meter of multi strand wire and 1 m of insulation
- 4 tubes
If you do not have the experience and necessary skills to work with electronic circuits, please do not purchase this product.
To purchase, visit https://abbasaudio.com/en/contacts
To see other products for sale, visit https://abbasaudio.com/en/store
2 — DAС 2.41 abbasaudio , KIT — $1600
The kit is designed for the TDA1541 chip.
The TDA1541 is included
Digital section : 6X5 ( EZ35), EAA91, E180F ( tube Dem clock)
Output level: 3.5v RMS
Set included:
- Two assembled and tested PCBs + 3 power transformers
- Rubber feet
- Wooden face panel
- 6 tubes
